Lanier 433b
  • kttyhwk
    • May 2018
    • 12
    Lanier 433b
    Machine say add toner, new toner installed, cleaned out toner transport tray
    just says add toner
  • LNorris
    • Sep 2008
    • 645
    Re: Lanier 433b
    how many copies on pcu?
      Re: Lanier 433b
      just says add toner
      what we have here is a FAILURE to provide information. We are GOOD... but not mind readers.
      other than cleaning out toner transport tray and installing a new toner... what have you done?
      what is the page counts on drum/dev/belt?
      did you clean out the supply tubes?
      is the machine clean inside?
      • copyaction
        • Oct 2007
        • 991
        Re: Lanier 433b
        Check the toner inlet on the PCU, if it is packed with toner chances are bad gears in the developer unit.
        as was mentioned if there is more than 60k on it, the PCU needs to be rebuilt or replaced
          • 37480
          Re: Lanier 433b
          If he had a large amount of toner in the tray that he had to clean out, I wonder if he had the old toner valve stuck in the chuck? I see this frequently. Correction. I took a look at kttyhwk's profile and it should be SHE not he. Sorry Kate you did put more information in your profile than many do and I did not initially check.
          • kttyhwk
            • May 2018
            • 12
            Re: Lanier 433b
            thanks for noticing slim, not many of us out here. and yes had a lot of toner in the tray in fact going to replace the tray, green handle way too stiff, mach has 182k on it
            • copyaction
              • Oct 2007
              • 991
              Re: Lanier 433b
              so are you saying the PCU has 182K on it and has never been changed, because that is the relative question
              if it was replaced every 60K then it would appear to be due again
              • guitar9199
                • Sep 2016
                • 1100
                Re: Lanier 433b
                Maybe a silly question, but was the nipple from the OLD toner bottle left behind in the hopper? I've seen that happen a couple of time, so it might be worth a look
                  • 37480
                  Re: Lanier 433b
                  Did you read the entire thread before commenting? I ask because, other than your slang terminology, I asked the same question yesterday.
                  • guitar9199
                    • Sep 2016
                    • 1100
                    Re: Lanier 433b
                    I used the "Slang" as you called it because I work on multiple lines... and none of them use the same terminology for everything, so I took a shortcut with the language.
                    ...In my defense, my caffeine levels were depleted....
