Ricoh MP 6001 SC816.
  • Milton_Freitas
    [Error Code] Ricoh MP 6001 SC816.
    Personnel good evening, I met with a ricoh MP 6001 with sc 816 already did controlpeter controler with film remover (alcohol isopropilico) and the machine comes to connect however after some copies taken and off the equipment the code appears. The interesting thing is that when I turn the machine off and on, the sc appears immediately.
  • eccelobo
    • 113
    Re: Ricoh MP 6001 SC816.
    First try to update the firmware. Good luck!
      • 37491
      Energy sub system error. System firmware needs to be v1.20J or higher. If not, update. If it is, reflash.
      Check if machine has embedded Equitrac solution
