Ricoh MP C5503 Pinting Quality with Color Shadows and Not Accurate
  • martinco02
    • Mar 2013
    • 24
    Dear Colleagues,
    Kindly need your comments what is happening on out Ricoh MP C5503. We tried already replacing the PCUs Assy - CMYK and ITB belt and unit. But still the same, printing with shadows or not accurate alligned. Please see sample attached. Thank you guys in advance!
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Re: Ricoh MP C5503 Pinting Quality with Color Shadows and Not Accurate
    Originally posted by martinco02
    Dear Colleagues,
    Have you at least tried the adjustments?
    1.User tools, maintenance button, auto color calibration.
    2. Make sure you clean the ID sensors. Then do the Forced line adjustment -- it may solve that color registration issue.
    • mikadonovan
      • May 2008
      • 2931
      If you have new pcu's installed, clean the laser shields with the blue stick, and run forced line adjustment (c twice, then run a). The magenta development unit looks to have a clump of toner at the doctor blade causing the line, or a clump at the drum cleaning blade. I know you said you replaced the K pcu, but there may be a problem with it if the shield cleaning doesn't get rid of the lines.
      NEVER ASSUME ANYTHING
      • tufbnme
        • 493
        Magenta and Black developer looks shot, replace and run the color alignment.
          • 37532
          Unneeded parts replacement is no substitute for proper regular maintenance. Everything I see on the color test pattern is due to a lack of maintenance.
          • martinco02
            • Mar 2013
            • 24
            Dear Colleagues,
            Good day, following the easy advise first works. Please see attached result after doing the following:
            1. User tools, maintenance button, auto color calibration
            2. If you have new pcu's installed, clean the laser shields with the blue stick
            Will check the other advise as well. But seems the result is now fine for the users.
            Thank you as always.
              • 37532
              Looks to me like you failed to do step 2 that blazebusiness said to do. If the ID sensor assembly is not properly cleaned or needs to be replaced, auto color calibration will not hold.
