NOT PRINTING ON EQUITRAC (MP 501spf)
  • sharpmind
    • Sep 2009
    • 478
    Guys, the client is printing through Equitrac. The display will just show printing and it hangs. There are four machines in their office with the same configuration and set-up. Only one machine is not printing in Equitrac.What could be the possible problem? see attached photo20180730_130453.jpg
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3945
    Re: NOT PRINTING ON EQUITRAC (MP 501spf)
    Was the 501 able to print before adding Equitrac? I had that happen once where Equitrac was being blamed for a machine issue.
    If so, and assuming ALL jobs are hanging, I would think the problem may be in how the machine is configured on the Equitrac server.
    I don't remember the server names, since it's been quite a while and I don't have one to look at.
    You may want to delete it from the server and re-add it. Also check the Equitac config on the 501's WIM. It may be different...I saw that happen once, too.
    • sharpmind
      • Sep 2009
      • 478
      According to local IT administrator, the machine is not printing since Equitrac is installed and the server is located in other country (United States of America)
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3945
        Then it's an Equitrac config problem.
        One thing I forgot to mention...are there enough machine licenses in Equitrac to cover them all?
        • rsyarcia
          Hair Straightener Tech
          • 711
          compare the pcc and java version from the working machines. had this issue before and we just updated the java.
          Nobody is perfect..
          • sharpmind
            • Sep 2009
            • 478
            problem solved by disabling the key counter..
