Wipe HDD
  • MHeon71
    • Oct 2008
    • 487
    Wipe HDD
    I am a Sharp/ Xerox tech and we are sending a few copiers back on lease return. The customer would like us to wipe the HDD, but is there anything that we should know first. Is there an automated way on a Ricoh and how would we get there. If we have to do it manually, can we just install a blank HDD and it boot up fine.
    Models dealing with - MP4002SP, MP301SPF, and MP6002SP. I have not seen the copiers yet, some may not even have HDD.
    Thanks in advance.
    Mark
  • FrohnB
    • Jul 2017
    • 1919
    Re: Wipe HDD
    You have to access Service mode and execute SP 5832 (HDD Formatting ALL). Some customers will accept that as a wipe, but we have also run into quite a few customers who wanted us to remove the HDD's so they could Shred it themselves. All of those models will be the same as far as the SP mode and service mode access code. Yes, you can install a blank HDD and all will be well, as long as it's the correct size and what not.
    Omertà
    • LNorris
      • Sep 2008
      • 646
      Re: Wipe HDD
      if you replace the HDD, a store hdd of same size will work, there is a format procedure when a new one is installed, just four SP modes to do that.
      • mincopier
        • Dec 2015
        • 290
        Re: Wipe HDD
        Be sure to charge for HDD replacement.
        • fshead
          • 2356
          Re: Wipe HDD
          and LABOR TOO.
          • Xcelsior
            Ex-Tech
            • Jan 2017
            • 24
            Re: Wipe HDD
            As FrohnB mentioned, you can use the Service mode to simply format the HDD and call it a day if they don't need an actual data erasure. However, depending on the customer/contract, you may need to do a proper wipe. Official Ricoh policy is to either do a HDD surrender or use the Erase All Memory option, both of which conform to the DoD/NSA standard of data deletion. All 3 listed models will have the Erase Memory option and the 4002/6002 will have HDDs installed (required to operate). The 301 I don't believe has a HDD option and stores data on the board/chip.
            To use the Erase All Memory option:
            1. Disconnect communication cables connected to the machine.
            2. The machine administrator logs in from the control panel via [User Tools].
            3. Press [System Settings].
            4. Press [Administrator Tools].
            5. Press [down arrow] eight times. (May vary per machine)
            6. Press [Erase All Memory].
            7. Select the method of overwriting.If you select [NSA] or [DoD], proceed to step 11. If you select [Random Numbers], proceed to step 8.
            8. Press [down arrow].
            9. Press [Change].
            10. Enter the number of times that you want to overwrite using the number keys, and then press [#].
            11. Press [Erase]. Deleting Data on the Hard Disk
            12. Press [Yes].
            13. When overwriting is completed, press [Exit], and then turn off the main power.
            The process may take several hours depending on the model, the data stored, method of overwrite, etc. It is worth noting that those machines likely had DOSS (Data Overwrite) enabled and most data on the HDD is already properly deleted, but Ricoh would not consider that enough.
            If you are simply going to remove/replace the HDDs, you only need to make sure a new HDD is installed and formatted in SP Mode to ensure proper functionality.
            Previous Ricoh Field Service Tech II - November 2017.
            • Zeldaman
              • Mar 2011
              • 946
              Re: Wipe HDD
              Hi there!
              Under the ID-code 984416 you can order the HDD-option for the MP 301.
              After reinstalling and formating the HDD execute sp 5-853-001 for uploading the stamp-datas. Forgot this once, and this was the customer who "needs" the stamp-function.
              Greetings...
              • ruben
                The New Guy
                • Oct 2012
                • 1203
                Re: Wipe HDD
                They should dispose of the HDD themselves. Handing over the drive to another could open themselves up to litigation.
                The built in HDD format is not perfect, neither is performing a manual format on a PC.
                  • 36748
                  Re: Wipe HDD
                  If the MFP has the Data Overwrite Security Unit installed and configured there is no need to wipe anything data wise. You still need to erase/initialize all address books. Before DOSU, Ricoh's published policy used to be remove the HDD and hand it to the customer's IT. If they wished to erase it and return it that was their option.
