PRO1357 replace fusing cleaning unit message
  • Voltageza
    • Jun 2017
    • 71
    Hi Guys
    I have a PRO1357 that keeps giving the following error "replace fusing cleaning unit" but the web was not finished. Changing the consumption back to "0" resets the code but only for a few copies? Any ideas?
    Regards
    Re: PRO1357 replace fusing cleaning unit message
    Originally posted by Voltageza
    Hi Guys
    Regards
    check the cleaning web sensor ( tells how much left...) they never run completely out.
      • 37486
      Actually the counter determines approximately how much is left. The sensor is for premature failure detection, web run off the end of the supply roller allowing the sensor arm to drop. It is also for detecting sloppy techs who think they don't need to follow the service when reassembling. Wiring harness can also cause web end messages.
        well different companies call it a different thing... point is you ( and others ) grasp what was trying to be conveyed.
        • Voltageza
          • Jun 2017
          • 71
          Changed the web end sensor and problem fixed. Funny, i always thought that the sensor being triggered results in a service code [emoji848]
