J057 DF exit jams on 6001
  • davydoodle
    • Jun 2018
    • 17
    Jams after the second original; did sensors, ow bearings on the back?
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: J057 DF exit jams on 6001
    with or without creaces?
    • davydoodle
      • Jun 2018
      • 17
      No creases...
        • 37546
        J057 is a trail edge exit jam. That means that the trailing edge has not left the sensor soon enough. Check to see if the first original is prevent the next one from dropping into the exit tray.
        • fshead
          • 2376
          If you ve cleaned all transport rollers,sensors,changed feed belt and sep roller then
          on these adf units the only odd issue i ve seen is one way bearings going and the adf feed clutch getting dirty or at times
          needing replacement.i shoot alcohol wth a paper towel to catch spray as i turn...
          Long shot bad harness if all else fails
          • davydoodle
            • Jun 2018
            • 17
            The first one make it out fully ok...
            • davydoodle
              • Jun 2018
              • 17
              Looks all direct motor driven....
              • NeoMatrix
                Senior Tech.
                • 3513
                google "site:wwww.Copytechnet.com DF MP6001"
                There's quite a lot of old threads relating to the topic.
                Below is a few old CTN URLS, you may find what you require.
                HTH
                Jamming Ricoh MP 6001 ADF misfeeds - CopytechnetYour browser indicates if you've visited this link.
                I remember folks swapping the DF drive motors as well ... Ricoh MP 6001 ADF misfeeds. Thanks, to everyone for your replies. I worked on this machine yesterday.
                copytechnet.com/forums/ricoh-savin-gestetner-lanier/12206...
                Jamming Ricoh MP 6001 ADF misfeeds - Page 2Your browser indicates if you've visited this link.
                [Jamming] Ricoh MP 6001 ADF misfeeds; If this is your first visit, be sure to check out the FAQ by clicking the link above. ... 6001 DF reg roller jam.pdf
                Mp6001 df jams and feed noises - CopytechnetYour browser indicates if you've visited this link.
                Mp6001 df jams and feed noises; If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: ...
                copytechnet.com/forums/ricoh-savin-gestetner-lanier/92959...
                Mp6001 DF jamming when duplexing - copytechnet.comYour browser indicates if you've visited this link.
                Mp6001 DF jamming when duplexing; If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: ...
                copytechnet.com/forums/ricoh-savin-gestetner-lanier/11412...
                Mp6001 DF jamming when duplexing - Page 2Your browser indicates if you've visited this link.
                  • 37546
                  Before or after the next one hits it.
                  One other possibility. If the lead edge of the second is not yet near the exit there is a possibility it is the first sheet that it is detecting as jammed. In which case it could be a bad exit sensor or dirty black reference. Dirty black reference will cause a delay in seeing the trail edge of the paper which will throw a jam.
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    could also be a false detection of the original format or orientation of the original...
                    The same problem with A4R, of A4 short edge first (SEF)?
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      Sorry, i mean "...OR A4 short edge first..."
                      • davydoodle
                        • Jun 2018
                        • 17
                        Any direction same jams, swapped sensors patches clean, changed ow bearings that drive feed in...
