Pro 8200 Dog earing
  • toddanderson
    • Dec 2005
    • 236
    Pro 8200 Dog earing
    I have a pro 8200 very random likes to dog ear only in duplex mode,
    can do it from every cassette , I removed the finisher and it still dog ears,
    My background is cannons and not a lot of experience with ricoh.
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: Pro 8200 Dog earing
    I haven't worked on this machine but my suggestion would be to look in the duplex paper path for any small broken guide fingers or other paper guide parts. There might also be a loose or missing latch spring in one of the plates that can be moved to remove paper jams.
    If it really is only dog earing when duplexing then your problem is likely isolated to the duplex unit.
      • 37489
      Ricoh is notorious for worn Mylar guides in the paper feed areas getting holes worn in them be the corners of the paper.
        well..
        since it is only doing it in duplex mode...from all trays...
        is there toner fused/unfused in the dogear? if in the fold... happening before fuser or at drum (after image transferred to page ) ...... unfused could be same w/unit set at plain paper much like a fuser running envelopes, but set on plain paper
        but first you need to check duplex path like others have mentioned.
        • TonerMunkeh
          Professional Moron
          • 3865
          Open the doors and pull out the transport bed. On the left hand side is a guide plate assembly with a solenoid on it. The spring on the solenoid slackens over time and causes dog earing and jam 40.
          Hit it.
          • toddanderson
            • Dec 2005
            • 236
            Thank you for everyone's help
            Their is no toner under the dog ear
            well..
            • MIKON
              • Jul 2015
              • 187
              Check foam rollers on exit roller.
              • toddanderson
                • Dec 2005
                • 236
                Thanks for ever-ones help I found some worn Mylars in the duplex section,
                replacing the mylars resolved the issue.
                  sounds like Slimslob nailed it then! give him a good rep!
