MPC4502 scan to mail default file name
  • solorajder
    • Jul 2010
    • 106
    Old machines like MPC4000, when you scan to mail, default file name was "year,month,date, hour,minute, secunds, milisec.".pdf, but on MPC4502 I get default file name without secunds and milisec. "year, month, date, hour, minute".pdf.
    Is it possible and where can I change default filename on MPC4502 to old "year,month,date, hour,minute, secunds, milisec.".pdf format?
    Thanks.
    • 37503
    Re: MPC4502 scan to mail default file name
    To my knowledge the factory default for file name never included seconds and milsec. It had to be added from the control panel then saved as default.
    • solorajder
      • Jul 2010
      • 106
      Can you tell me exactly where in control panel?
      Sent from my I9195I using Tapatalk
        • 37503
        Depending on the model, either in Scan Settings in User Tools or for newer models in the scan function itself. Or are you too lazy too look for it?
        • solorajder
          • Jul 2010
          • 106
          If you don't have a clue, please be quiet.
          The right answer is that the old machines (MPC3000, MPC4000, ...) default file name is with "sec., msec." but newer model (I tested with MPC3002, MPC4502) default file name is only with "...hour, min."
          This can be changed in Scanner SP 1-015 (Time stamp to file name).
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            And the red cards continue
