mpc2800 skew image - both print and copy
  • Mark Bbb
    • Jun 2012
    • 1662
    both print and copy...
    Have looked on this site to see if there was a threat, but as far as i can see, there was n't.
    Have you seen this model skewing?
    Thanks for your help.
  • floody
    • Mar 2017
    • 37
    Re: mpc2800 skew image - both print and copy
    have you tried printing from a different tray?
      • 35241
      The side fences in the paper tray(s) might not be against the paper.
      • Mark Bbb
        • Jun 2012
        • 1662
        Hoi,
        Yes, with all trays.
        Slim: Fences ok.
        Seems that, when i swap duplex unit with good one, problem is gone...
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          Originally posted by Mark Bbb
          Hoi,
          Slim: Fences ok.
          Have you inspected the Transfer case?
          Most likely it doesn't have the modified case and is broken.
          That would be the reason why you're getting a good result with a different duplex maybe?
          Transfer case parts.pdf
          • Mark Bbb
            • Jun 2012
            • 1662
            [ATTACH]40469[/ATTACH]
            It is a new modified PTR...
            I will investigate this later, keep you informed.
            • fshead
              • 2356
              there are two pressure springs in the transfer case unit that might have become unlatched.
              That is why I like parting out old units just to have a "quick fix" in case it is not the normal items to fail..
              • Tecnicopia
                • Jun 2015
                • 31
                And the internal black guides? On the main frame. Usually are broken too.
                Enviado desde mi Redmi 4X mediante Tapatalk
                  • 35241
                  There is also the registration roller bushings, B2382675, that the tension springs, B2382676, hook onto to apply pressure between the rollers. I have seen it more on entry level B/W where the hook on the bushing that the spring attaches to breaks off.
                  • Coptech
                    worker drone
                    • 460
                    mylar on guide just ahead of registration nicked and catching.
                    • Tecnicopia
                      • Jun 2015
                      • 31
