BK5030 error BK069
  • slot
    • Jul 2008
    • 341
    BK5030 error BK069
    Could anyone please teel me what error BK 069 is the paper gets to the staple area all ok the jogs paper then errors i cant find the cod in the manuale thanks in advance.
  • slot
    • Jul 2008
    • 341
    Re: BK5030 error BK069
    found the info i needed in the pbm350 manual BK-069 Staple Detection Clinch Left Sensor BK-Q19 Short Circuit
    This Fault code indicates that the Clincher is shorted to frame or GND.
    Possible failures: - Staple or staplerhead is in contact with the clincher. - Short in sensor cable that goes to clincher BK-Q19 (PL 7.0).
    Initial Actions Ensure that both Stapler Heads are in upper position. Ensure that Connector "Clinch Left" and "Clinch Right" are connected.
    Ensure that Connector "J39 / P39" and "J40 / P40" are connected.
    Ensure that Connector "A.P1" is connected.
    Check all cables to above connectors are not damaged.
    Procedure Disconnect plug A.P1 from CPU/Controller PCB "A". Measure between J1-24 and Chassis/GND (Signal and GND)
    Replace CPU/Controller PCB "A".(PL 3.1) Disconnect plug "Clinch Left" Check white wire to A.P1-24 to frame.
    Is there a short circuit Y N
    Check J4 at Left Clinch to frame for short circuit. Is there a short circuit
    Y N
    Replace Clinch Left (PL 7.0)
    Replace/Repair Wire Harness.
    Replace/Repair wire harness.
