MP2852 sc990
  • Blazer1087
    • 195
    MP2852 sc990
  • davel
    • Oct 2011
    • 1103
    • sandmanmac
      • 3981
      Re: MP2852 sc990
      Originally posted by Blazer1087
      The co we bought the copier from says the firmware is up to date. I don’t have a way to get current version numbers so I take there word on that. Any idea what might be going on here?
      The SC relates to either corrupt or Outdated F/W, or defective controller.
      The current F/W versions are easily viewed via the WIM, and you could copy/paste them to this thread and let us advise you just how current it is, but the bottom line is, at a minimum the F/W should be re-installed, and if the issue persists, then most likely you've got a defective controller
        • 37480
        Re: MP2852 sc990
        By changed out the PCU do you mean swapped with another machine or installed a new or properly rebuilt (PM) one. SC990 can also indicate a machine that badly in need of a full PM.
        • Blazer1087
          • 195
          • Blazer1087
            • 195
