Hello all,
I wanted to reset the admin password and found out that this is possible with the "supervisor" user. I can login with "supervisor" on the web and local maschine, however when I try to change the admin password I'm not able to login as admin.
On the web version I figured out that there is an additonal step in the overview to apply the password which I have done.
What I noticed is that in the overview no roles could be changed and none are selected:
I also noticed that the machine tells me on startup that the address book is corrupted (I haven't used it).
I wouldn't care to get admin access if scanning per mail would work. This is a used machine bought cheap for private usage.
Are there any things I forgot? I'm thankfull for all hints
