SPC840dn PCDU mods
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    SPC840dn PCDU mods
    Hey guys,
    We have a bit of an issue where we have a crap load of D2442204 (or D239) PCDU on back order for the MPC2004/2504 machines.
    The Service manager at Ricoh has suggested that we use the 408034 and 408035 maintenance kits.
    Yes...I can hear you all typing "Why are Ricoh recommending the use of maintenance kits in a copier model" ..we though the same.
    Has anybody here used the maintenance kit at all?
    Any mods to be done?...I assume it'll need the TD sensor swapped over.
    Also...in the TPRD for the SPC840dn there are TWO different Maintenance kits.
    One is a User replaceable version with a 60k pm cycle and the other is a Service Maintenance model and rated at 200k.
    Any advice is appreciated
  • davel
    • Oct 2011
    • 1109
    Re: SPC840dn PCDU mods
    Fitting one tomorrow to a 4504, will let you know.
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      Take some pics for the larger forum community ?
      We've ordered a Black pcdu and colour kit,an ITB assy and a fuser...going all out
      • Imprestik
        • Aug 2012
        • 297
        Oze the SPC840 kits wont fit into a 2004/2504 they are completely different
        they do fit into a 4504/6004 with modification
        • Gift
          • Mar 2011
          • 2459
          Correct - you need to swap the Toner density sensor and the front cover won't fit without cutting away some plastic or leave it away. You also should use manual new unit set SP for initializing the new unit properly.
          • davel
            • Oct 2011
            • 1109
