Ricoh MP 2553 PRoblem
  • ecnereht
    • Sep 2018
    • 40
    Hi,
    We have a Ricoh MP 2553 Printers that causing black dots on every pages when printing.
    Please help.
    Thank you.
    TSL
    Re: Ricoh MP 2553 PRoblem
    Originally posted by ecnereht
    Hi,
    Please help.
    Thank you.
    TSL
    what is the distance between dots? have you looked in the manual for the defect ruler?
    did you try pulling the drum and looking for a spot on it?
    • ecnereht
      • Sep 2018
      • 40
      Im not sure for the distances of the dots but when I pulled the drum there are spots on it.
      • guitar9199
        • Sep 2016
        • 1100
        How many copies/prints on this machine? Drum and developer on this series is rated for 60K Copies.
        • keithxxiii
          Just a tech
          • Nov 2014
          • 468
          Print the counter page then look for those dots. If the dots are repeating on the same measurement, then you have a problem on your drum. If the counter is above 60k from the last replacement, then you have to replace it together with the developer, blade and charge roller/brush.
          Aye! Cut the crap
            • 37377
            Drum spots are a symptom of trying to go too far between PCU PM. Usually start to show up at the outer edges of the drum at about 75K. Trying anything other than PM with a new drum will only make it worse.
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Time to call a tech to service your machine.
              • ecnereht
                • Sep 2018
                • 40
                Yeah, I believe its a drum problem. Its more than 60K copies. I thought I can still do something to extend more.
                TSL
                • ecnereht
                  • Sep 2018
                  • 40
                  If the same measurement of the distance of the dots (only drum replacement?).
                  If 60k above copies - replace all PCU unit?
                  TSL
                  • ecnereht
                    • Sep 2018
                    • 40
                    Sorry, but what is PM?
                    TSL
                      • 37377
                      TSL
                      If you have to ask that question you should not be working on copiers of any type. Hire a knowledge tech.
                      • ecnereht
                        • Sep 2018
                        • 40
                        I am a technician but not too much of an expert.
                        TSL
                        • Gab
                          • Aug 2015
                          • 669
                          replace drum , dev and blade.
                          • ecnereht
                            • Sep 2018
                            • 40
                            It means the whole PCU unit?
                            TSL
                            • blazebusiness
                              SanDiegoCopierRepair.com
                              • 1250
                              TSL
                              You can replace the Ricoh MP 3352SP 2852SP 2352SP MPC3352 Drum Unit Part# D1203000 but you will also need to replace the
                              developer Part# B1219645.
                              OR you can rebuild the Drum unit(PCU) but you will need the following:
                              RICOH PMB20560K MAINTENANCE KIT - 60K
                              Drum part#B0399510
