MPC6000, C6055 postscript card
  • RandyW
    • Jan 2013
    • 213
    Can you take a postscript card from 1 machine and put it in another machine?
    Had someone get 1 off the internet and it is not working in their machine.
  • LNorris
    • Sep 2008
    • 645
    Re: MPC6000, C6055 postscript card
    PS cards cannot be swapped. but print the config sheet of your c6055 and see if PS is already loaded.
    • keithxxiii
      Just a tech
      • Nov 2014
      • 468
      PS Cards can be swapped with the same model. A little tweaking can be done on those old models (C2051 for example).
      Aye! Cut the crap
      • RandyW
        • Jan 2013
        • 213
        We ended up with the sd card back at our office.
        We had another C6055 here that had the Printer/Scanner sd card in it so I looked at the files on that card and compared them to
        PS card our customer had purchased. I then put the PS card in my PC and removed those files that matched the #2 machines printer/scanner card.
        We went back over there and this time were able to merge their printer/scanner info on to the PS card.
        They are now printing with their MACs to their machine.
