SPC 352DN with SC 332 - 01
  • Roger67
    • Nov 2013
    • 84
    Hello,
    i have a SPC 352DN with a SC 332- 01
    I changed all PCU an checked if the Black Toner Bottle works ( runs ) correct.
    Any ideas ?
    Roger
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1246
    Re: SPC 352DN with SC 332 - 01
    Originally posted by Roger67
    Hello,
    Any ideas ?
    Roger
    Add toner by hand to the black PCU. If the unit prints a few pages before the code returns you obviously have an issue with the shutter not opening or a bad toner supply clutch. Not completely sure but I'll bet the toner supply clutches are the same for all 4 colors so maybe you can swap the black clutch for one of the color clutches to diagnose the issue.
    • Roger67
      • Nov 2013
      • 84
      Hi Folks,
      finally i am happy to inform you,that i already fixed the Problem of this Maschine.
      A Plastic-Part (shown in Picture ) blocked the alu-Rail of the open-mechanism of all the
      Toner-Bottles ( Position marked with 2 XX ).
      I dont now what and where this plastic Part came from..................
      greetings
      Roger
