Good morning, fellas! Here's one to mess with your brain (it did with mine):
Got an old (of course) MP9000 that started with a SC220, which was solved by replacing the LD unit.
Now everything's fine except for the Printer feature that is not recognized.
When I press the Printer button, it double-beeps.
If I format the HDD and then reboot the machine, it gives me a red Printer button and SC997 on the printer screen.
If I reboot again, it double-beeps once more.
Formatted both HDDs on a Windows PC and placed them back, without success. Also cleaned RAMs and double-checked boards connections.
Scanner function gives no problems.
Do I have a bad Scanner/Printer SD card? Or could it be something else?
Thanks!
Thanks!
