SC544-00 Error at Ricoh MP2553 Copier
  • ecnereht
    • Sep 2018
    • 40
    Hi All,
    We are having difficulty to even reset the error. What causing this error?
    Thanks in advance.
    TSL
  • guitar9199
    • Sep 2016
    • 1100
    Re: SC544-00 Error at Ricoh MP2553 Copier
    SC544
    Fusing overheat error
    • ecnereht
      • Sep 2018
      • 40
      Originally posted by guitar9199
      SC544
      Ok. I hope its the fusing unit only that I need to change. Not PSU nor BCU. (fingers crossed).
      Thanks bud.
      TSL
      • davel
        • Oct 2011
        • 1101
        Read your manual, what have you replaced so far.
        • ecnereht
          • Sep 2018
          • 40
          Not yet. We are doing further checking on the copier. We are ordering brand new Fusing Unit from our supplier to replace it. Then, we start from there.
          TSL
          • davel
            • Oct 2011
            • 1101
            Have you tried resetting the fuser SC code? It is in the manual.
            • ecnereht
              • Sep 2018
              • 40
              Yes, I did. But its still the same.
              TSL
              • keithxxiii
                Just a tech
                • Nov 2014
                • 468
                Have you replaced the fusing unit and reset the code? You might need a BCU and PSU also.
                But before posting, make sure you have checked your manual and did the necessary steps
                Aye! Cut the crap
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  A complete fuser is a bit of a stretch, hot roller, pressure rollers and thermistors definitely, but a whole new fuser?
                  Hit it.
                  • guitar9199
                    • Sep 2016
                    • 1100
                    If the rollers are in good shape, and the machine or fuser has less than 120K on it, then likely all you'll need are the thermistors. Sometimes all they need is a cleaning, but be prepared to replace them.
                    • ecnereht
                      • Sep 2018
                      • 40
                      Noted on this. Will keep posted on the updates.
                      TSL
