Ricoh MP 3045 toner light
  • stek
    • Sep 2015
    • 15
    [Misc] Ricoh MP 3045 toner light
    Hi all!
    Have a Ricoh MP3045 with a toner light that won't go out. After the toner was replaced we replaced developer and the toner tray mechanism. The machine is able to add toner in service mode (force toner) but then the light will come on in 20-30 copies. I also increased the toner supply rate but no luck.
    Thanks!
  • eccelobo
    • 113
    • stek
      • Sep 2015
      • 15
      Re: Ricoh MP 3045 toner light
      The developer is new and the drum has less than 20k
      • TonerMunkeh
        Professional Moron
        • 3865
        If you cheat the front door and look into the toner hopper, can you see the bottle turning when it's trying to add toner? Which developer did you use?
        Hit it.
        • FrohnB
          • Jul 2017
          • 1919
          Agree with tonermunkeh, have had many toner bottle motors go out on this series. That's one thing to check. Otherwise, check to see if there's a plug left in the toner hopper, or the plug to block toner chute on PCU unit when you flip it over. Did you initialize the new developer with 2-801 when you changed it? Possible bad TD sensor in Development unit, swap with a different/new one if available and see if it holds toner concentration.
          Omertà
          • stek
            • Sep 2015
            • 15
            Thanks! Yes I used the proper Ricoh developer. I can hear the machine trying to add toner but I did'n take a visual. I will try this next.
            • stek
              • Sep 2015
              • 15
              Thanks! I did check for a plug. I did initialize the dev too. Would the dev initialize with a bad TD sensor?
              Thanks again!
              • fbkhan3
                • May 2012
                • 421
                if you can see the toner bottle rotating when force toner is executed, then dismantle the toner Hopper ,carefully look for 4 Mylars inside, these actually tend to flip or drop with wear and tear. you can either glue them back or change the hopper . this has been the case with 2035,2045,DSM 35/45 series.
                Edit: if toner Tray mechanism means toner Hopper unit replaced then kindly ignore the post.
                Regard's
                  • 37393
                  Are you sure you have the correct toner bottle? Some older models used a different bottle. Same diameter, same length, the only difference was the bottom of the bottle where the toner motor drives the bottle.
                  With the previous model number, the 2045, there were two different version. The 2045 and the 2045e used different bottles. Symptom of the wrong bottle was exactly what you are getting.
                  • stek
                    • Sep 2015
                    • 15
                    Regard's
                    Thanks! Yes the hopper is new!
                    Thanks!
                    • stek
                      • Sep 2015
                      • 15
                      I will double check the toner type but they get it from us...
                      Thanks!
                        • 37393
                        Thanks!
                        You might want to double check your shelf stock also.
                        • Oze
                          Ricoh Fanboy
                          • Jul 2008
                          • 1663
                          When these units come due for a PM we generally just replace the entire PCDU which come pre loaded with dev.
                          The only time I've struck something like this was when I replaced the PCDU and forgot to remove the bung from the dev unit...woops
                          Copies would go light.....and you could perform a forced toner successfully(according to the SP result) but copies would stay light.
                          Took me a good 20 mins to figure that one out.
                          • whitecat
                            • Nov 2012
                            • 43
                            put some toner from bottle into developer unit ( about 2 spoons ) .
                            do about 50 prints , c if quality changes
                              • 37393
                              Obviously you have not read this original post. This thread has to do with the add toner light staying on, not light CQ.
