Swap MP 4000 PCDU unit
  • mdtrinh
    • Aug 2010
    • 68
    Is that possible to replace a good PCDU (Drum & Developer) unit from other machine without changing any setting?
    We did it with MP 4002 without any issue. In the old day, we needed to get Vref from the unit machine, AF 2045 series if we remember correctly.
    Thanks!
  • mikadonovan
    • May 2008
    • 2931
    Re: Swap MP 4000 PCDU unit
    I've done it on occasion with other models. Install and run a print to check for quality. If ok, set developer and you should be good to go
    NEVER ASSUME ANYTHING
      • 37560
      Just run the same SP as if you have done a PM.
