Ricoh MP301SPF: Using duplex as default setting in scan
  • Ninelpienel
    • Sep 2018
    • 5
    Hey, is it possible to set duplex as default setting in scan? When a customer want so scan everything with duplex it's annoying for him to change this setting every time.
    Regards.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MP301SPF: Using duplex as default setting in scan
    Yes, use the program features key. It's a diamond with an arrow pointing out of it. Make your settings, then press that key, then program as defaults.
    Hit it.
    • Ninelpienel
      • Sep 2018
      • 5
      Wow, nice! Thank you! I see that I can create programs with this button. Can I also create a scan program with a predefined target from the address book?
      • TonerMunkeh
        Professional Moron
        • 3865
        That one I'm not too sure on. I think there's an setting in scanner SP that's called something like "user info release". If that's disabled it doesn't reset the scan destination, but I don't know if it will work the way you need it to.
        Hit it.
        • Ninelpienel
          • Sep 2018
          • 5
          No. :/
          This setting just doesn't clear the destinations after the scan.
          • ridgemill
            • Sep 2017
            • 190
            If you always use one destination, then you can save it to the home screen as its own button.
            See: Adding Icons to the [Home] Screen Using the User Tools
            Instructions above mention using Copier Program, you will need to use Scanner Program instead.
            • Ninelpienel
              • Sep 2018
              • 5
              But how can I create a scan program with a predefined destination?
                • 37524
                Setup the scan as normal then use the program button to save it as a preset.
                • Ninelpienel
                  • Sep 2018
                  • 5
                  This doesn't work for me. It only saves the scan settings.
