how to convert mp4001 to 5001
  • chand226
    • 38
    how to convert mp 4001 to 5001
    and mp 4000 to 5000
  • icese
    • Oct 2012
    • 8
    Re: how to convert mp4001 to 5001
    [QUOTE = chand226; 700490]如何將mp 4001轉換為5001
    並將mp 4000轉換為5000 [/ QUOTE]
    更換前門蓋的型號。(把前門蓋的型號更換就可以了)
      • 37328
      Translation:
      Replace the model of the front door cover. (Replace the model of the front door cover)
      This will not change the speed of the machine. The model is also on the serial number plate. If you want a 50 ppm machine you need to buy one. If you really want to try, you will need to replace the controller board and the BICU. You will also need the front door and back cover with serial number from a 5001.
      • fshead
        • 2360
        easy>>
        a sharpee that can turn the 0 to 1.................
        I always get a kick with these "Young Frankensteins"....
          • 37328
          With all the things that you are going to have to take off an existing 50 ppm machine why not just use it.
          • fshead
            • 2360
            well at least he didnt ask how to make a color copier into a b/w...........
            • chand226
              • 38
              haha
              • keithxxiii
                Just a tech
                • Nov 2014
                • 468
                5907 changes your model....but not the speed
                Aye! Cut the crap
                  • 37328
                  If I remember correctly, it only allows you to change make. It will not allow selecting a model that does not correspond to the speed identified by the serial number.
                  • fuwei2422
                    • Nov 2014
                    • 49
                    first : CTL
                    sec:BICU
                    • jonhiker
                      • 661
                      give him a box of color crayons....
                      • Michael Craig
                        • Dec 2016
                        • 12
                        The cost of the parts exeeds the value of the machine.
                          • 37328
                          Surprise Surprise Surprise
                          • Butrus
                            • Jan 2012
                            • 115
                            I would start by comparing parts manuals
                            Often interesting results occure....
                              • 37328
                              And what makes you think we have done that. This not the first time we've seen this question.
