Ricoh MP501 Opinion
  • Voltageza
    • Jun 2017
    • 71
    Ricoh MP501 Opinion
    Hi Guys
    Can i please have you guys opinion on this machine in terms of the making yields on toner and parts. I see that the parts have quite high yields.
    • 37556
    Re: Ricoh MP501 Opinion
    Expected toner yields should be printed in the Product Support Guide. Mind you that is the expected yield and based on a standard coverage of, I believe, 5%. Customer yields will vary based on coverage.
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      They have high yields because I believe these are a rebadged Kyocera.
      • dpoutz
        • May 2011
        • 78
        Yes it is a Kyocera 3550 i believe same except no smart op panel
        • donking289
          • Mar 2017
          • 28
          Not one fuser has lasted to yield.
          • JonManchester
            Technician / Shop Manager
            • Aug 2013
            • 103
            We just had a pcu crap out at 140K and the fuser hot roller was ghosting copies but was able to clean the roller to eliminate ghosting. Also had to replace tray 1 lift mechanism due to breakage causing noise. Other than that there ok i guess. Also has some squeaking going on.
            Live for something or die for nothing.
            • davel
              • Oct 2011
              • 1107
              POS just like MP401.
              • skinnyb
                • Jul 2008
                • 291
                I agree. 401, 402, sp4510, 4520 all junk.
                Sent from my VS987 using Tapatalk
