Toner Coverage Calculator
  • Voltageza
    • Jun 2017
    • 71
    Hi Guys
    I am in search of a toner coverage calculator program/app. I need to import a image and then get a report of how much coverage of each colour (Black,Cayn,Magenta,Yellow) are going to be used when making a print.
    Thank You
    Re: Toner Coverage Calculator
    Originally posted by Voltageza
    Hi Guys
    I am in search of a toner coverage calculator program/app. I need to import a image and then get a report of how much coverage of each colour (Black,Cyan,Magenta,Yellow) are going to be used when making a print.
    Thank You
    ummmm don'tcha think giving us the MODEL # of the unit would be helpful?
    • Voltageza
      • Jun 2017
      • 71
      I want to use it with any colour mfp. Especially copyshops to determine the colour coverage the image has per colour so the cost of toner per print job can be calculated.
      • mincopier
        • Dec 2015
        • 289
        Not a utility but here is an online calculator:
        FREE Online Ink & Toner Coverage (Consumption) Calculator – dejaWorks
          • 8159
          Your copy/ print devices do not have a built in pixel counter to estimate toner coverage?
          The pixel counter is not a bible of truth but it will give you an idea after a 30 day average of what is happening.
          Print shops will take any job that pays so if it is 100% toner coverage all day long they will claim that your profitability is not their problem. Your company proposed the Service Maintenance agreement, you have to live with it.
          Print shops will be big on pushing heavy card stock through the copier and this accelerates wear on all of the internal components.
          • valex
            Try to use APFill Ink and Toner Coverage Calculator 6.0. It takes a PDF file and calculates CMYK separated coverage for each page of a document.
            • giogi
              Engineer senior
              • Jan 2016
              • 181
              flash is no longer supported by Adobe
              this SW doesn't work now
              "Knowledge is a source, but unfortunately ignorance is a sea."
                • 37398
                Two and a half years late to the party and with possibly with incorrect information. Due to the demand for a way to play flask/shockwave video files Adobe has released Adobe Shockwave Player. The latest version 12.3.5.205 was released Mar 30, 2019. Adobe Shockwave Player - Download
