DF3010 (mp4000, mpc3500)
  • Mark Bbb
    • Jun 2012
    • 1662
    After it works fine, suddenly multifeed (about 15 pages at once), even with single face scanning.
    Replaced reverse roller unit (with torque), no good.
    I haven't seen this one before, anyone?
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: DF3010 (mp4000, mpc3500)
    One of the gears that drives the reverse roller can crack, seen that before. Also the one way bearing under the feed belt can get a little sticky.
    Hit it.
    • FrohnB
      • Jul 2017
      • 1919
      Tonermunkeh is most likely correct (again) !!
      Omertà
        • 37532
        You're not clear here. Did you or did you not replace the torque converter?
        • Mark Bbb
          • Jun 2012
          • 1662
          Hoi Slim:
          Yes i did replace the torque limiter.
          In fact i took the reverse unit (reverse roller and torque) from another good working DF and it was no good.
          So, tonermunkhey is probably wright.
          (It seems like a very lot of work to replace those one ways gears... )
          • Athlontini
            • Jun 2012
            • 269
            This is always the culprit, in my experience. The part number for the gear/shaft is B8022231.
            • sandmanmac
              • 3981
              Agreed. Had this myself just last week
