Looking for more info on SR3150 sorter
  • fshead
    • 2356
    HI
    I just picked up a few extra sr3150 Booklet finishers and want to "be clear" what they can do.
    I see it says it can saddle stitch but from i saw it looks like it uses the type k staples not the bigger "roll of wire type"Type H
    i ve seen on the bigger sorters .
    Does this sorter use two types of staples?
    I assume you can make books but would like a clear view of where i should place them.
    thanks
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: Looking for more info on SR3150 sorter
    Originally posted by fshead
    HI
    thanks
    It only uses type K staples. It has a staple capacity of 50 sheets of regular weight 8.5x11. The machines that take type H have a 100 sheet capacity.
    It uses Type K refills, but I believe the cartridge is Type S.
    • fshead
      • 2356
      thanks
      i gotta unwrap them and open them up to learn more.
      I guess i will connect one up to my last mpc3003 i have in shop and play with it.
      FOR some reason i thought saddle sticth could only work with the "wire type staplers..
      I guess its been a while for servicing print shops wth extended finishing needs.
