Ricoh MP2851 fuser entrance guide plate
  • COPIERMAN
    • Jun 2009
    • 559
    I have look at parts manual MP2550/2851/2852/3353 and show part #d1204085 but when i go to install part the lip in middle of it is short and wont slide in place. Does someone know correct part number for item.
  • chris2882
    • Mar 2011
    • 11
    Re: Ricoh MP2851 fuser entrance guide plate
    A267 4085 Fusing Entrance Guide is what my book says for the 2851/3351
      • 37062
      The D120 part number is for the 52s and 53s. The A267 is for the 51s and everything else all the way back tho the Aficio 220/270.
      • COPIERMAN
        • Jun 2009
        • 559
        everyone is correct on part # so either the part is made wrong that i receive got 3 them all same way were in middle of guide there is a lip that fits under the lower fuser frame. i took a fuser entrance guide off MP2852 that i had and you can see it is a little longer. i guess for now will cut off so it will fit right. Thanks for the help on this.
        • sandmanmac
          • 3973
          Dude.
          The part number you provided is the one for 52/53 series
          The CORRECT part number provided by others (and apparently the one you need), is for the 2851, and previous models.
          What aren't you getting?
          The parts are different.
          Try using the right parts catalog next time
