Ricoh mpc3002 error sc544
  • vicalvarez
    • Mar 2014
    • 33
    [Error Code] Ricoh mpc3002 error sc544
  • sandmanmac
    • 3969
    Re: Ricoh mpc3002 error sc544
    The SC is only reset by a fuse on the replacement fuser. If your replacement fuser is used, then the fuse has already been blown and it won't reset.
    This thread has some other solutions to get around replacing the fuse.
    Read it: MPC-3502 sc554-00(holy sh..!)
    • jonhiker
      • 661
      the fuse comes with the sleeve. the best way to solve the issue is to replace the sleeve and put in the new fuse.
        • 36903
        When you order a new fusing sleeve from Ricoh, they package the fuse needed to reset in the bottom of the box.
        • jhalfhide
          • Apr 2015
          • 451
          • Gab
            • Aug 2015
            • 664
            Usually when a part has a standard life there are a fuse that blown . If you replace this fuse , it will be ok.
            • fshead
              • 2356
              make a push button switch from a scrap machines small door switch,lite wire and an old thermister"mp6000" end connector and connect,service mode,execute fuser reset as you press the switch..'may take a few attempts as timing is important...
              • vicalvarez
                • Mar 2014
                • 33
                Thanks was a dirty thermistor and reset with a fuse
                Enviado desde mi iPhone utilizando Tapatalk
