wide format color mpcw2201 mochac2
  • en.
    • Jul 2014
    • 124
    hi all
    I have a problem with the mpcw2201 wide format color A0 device. The problem is that every day when I do a print job there is no black ink and there is a clog in the black head after I do the maintenance from user tools ( cleaning and flushing ) for black head The machine works normally and prints black after turning off the machine and running it the next day. Prints black is not working so im doing (cleaning and flushing ) every day again and again and again every day to works fine ... if any one know what the problem exactly and what should i do ?
    best regards
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: wide format color mpcw2201 mochac2
    If the print head is blocking that often I'd replace the maintenance unit. If that doesn't sort it, replace the black heads. Are you using Ricoh ink?
    Hit it.
      • 37643
      Do you have the machine to do automatic cleaning and purging at power on?
      • mikadonovan
        • May 2008
        • 2931
        There was a bulletin issued for this problem in Decenber 2017. It concerned the K2 cap not sealing and causing it to dry out within 24 hours. The fix was to replace the maintenance unit (new units have a modified filler nozzle).
        NEVER ASSUME ANYTHING
        • en.
          • Jul 2014
          • 124
          thanks for your responding : i don t know ...is there any way (sp mode ) or any think else can doing to make device automatic cleaning and purging ?
          • MitchD
            • Oct 2012
            • 164
            This all day. I had a brand new unit that had this exact issue. I swapped the Maintenance unit and all has been well since.
            "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
            • JDYAL
              • Sep 2008
              • 187
              Same with me had two machines with this problem and maint. kit fixed it.
              • mikadonovan
                • May 2008
                • 2931
                On a cw2200, you can adjust sp2521-003 to 2, and set 2513-001 to 3. Refer to tech bulletin D124-007R. This adjusts the cleaning cycle and the amount of time between cleanings.
