MPC3503 PCU Problem
  • Bozz
    • Oct 2014
    • 16
    MPC3503 PCU Problem
    Re: MPC3503 PCU Problem
    Originally posted by Bozz
    [ATTACH=CONFIG]40823[/ATTACH][ATTACH=CONFIG]40822[/ATTACH][ATTACH=CONFIG]40824[/ATTACH][ATTACH=CONFIG]40825[/ATTACH][ATTACH=CONFIG]40826[/ATTACH]
    poster SIZE or weight... heavy stock = greater wear om parts
    is the machine counting the A3 as or page or double click?
    • davel
      • Oct 2011
      • 1095
      What is the count on dev units.
      • fshead
        • 2360
        is it always serviced by you?
        Is it in a "pig environment wth lots of dust,chemicals,heat?
        I just gave up on a low meter 60k mpc3002 that was filthy and even the metal
        parts started to corrode.....
        Did you try to wipe the drum to make sure it is not just a nasty film?
        DID YOU check the lube bar and roller?
        I am not a big fan of the new roller that the lube bar sits on.
        The mpc2800,c3001,c3002 all had the one that mimicked the mp6001 b/w drum cleaning roller,
          • 37375
          Check the condition of the surface of the ITB. If it is similar to the drums then it is definitely the paper as Phil said. There could also be build up of duct or paper lint on the cleaning blades causing wear.
          • Lagonda
            • Aug 2008
            • 1649
            Are you using genuine Ricoh PCU's? We just tried using non Ricoh kits to rebuild the colour PCU's in an effort to cut the cost of colour PCU's and gave up in disgust when the supposed genuine "Ricoh" drums started to peal the surface off after 30k.
            • FrohnB
              • Jul 2017
              • 1919
              Are you Remembering to move the Springs for the Lube Bar when replacing the PCU's? If you don't do that, then you will only get about half of the Yield (not the 270k stated in PSG). I don't know why they had to add that "extra step", my guess is that if a "non-tech" were to somehow replace the drum successfully (but not know about the springs), then they will get early failure, and Ricoh or whoever will get another call for that part ($$$$$$ - for Ricoh), really dumb in my opinion. We've had BLack drums go up to around 500k consistently on this series.
              Coverage percent I thought was in the 7-xxx section somewhere in the SMC.
              Omertà
              • guitar9199
                • Sep 2016
                • 1100
                Are you using GENUINE Ricoh toner, or aftermarket?
                I've seen some aftermarket toner that's very abrasive, and it wipes out drums WAY sooner than their expected life.
                • davel
                  • Oct 2011
                  • 1095
                  Spring move is only needed for 5503/6003.
                  • FrohnB
                    • Jul 2017
                    • 1919
                    That's what they say! But we always move the spring, it would be stupid not to. 1/10 of it's yield!!!!!
                    Omertà
