scantoftp without using ftp software
  • aviso66
    • Dec 2012
    • 202
    [Misc] scantoftp without using ftp software
    Hi,
    I am wondering if I could setup scan to ftp ricoh machine without having to install a file zilla server? I am wondering if it works like if I allow a certain port to be open and allow the ricoh machine to scan through.
    thanks
  • mansart
    • 852
    Re: scantoftp without using ftp software
    You can use built in FTP .....
    FTP Win10
    I would recommend using....
    Quick 'n Easy FTP Lite
    • aviso66
      • Dec 2012
      • 202
      FTP Win10
      thans i have tried ftp win 10. it works. but does it need to use the fixed ip in order for it to work?
        • 37488
        And the problem with that?
        • NeoMatrix
          Senior Tech.
          • 3513
          Re. FTP to local NAS.
          This NAS FTP can be set up the same with a Dynamic DNS. A normal home/small office router NAS can be programmed to forward its IP to an internet domain name server(dynDNS) over a set programmed period. This will allow you to find the home/Office NAS via IP-address over the internet.
          I'm not fussed about having a running home FTP system open over the internet, but its' quite okay to do it this way. Each to their own....
          All in one I.T. Tech software.
          htttp://www.copytechnet.com/forums/connectivity/97276-all-one-i-t-tech-software-post694379.html#post694379
          HTH
          • fshead
            • 2376
            i use scan to pdf all the time on both older and newer machines by downloading the twain driver and selecting that machine via the interface
            On top>FILE>SELECT SCANNING DEVICE>SELECT TWAIN SOURCE
