MP5054
  • GeorgeBest
    • Jul 2009
    • 525
    MP5054
    Hi,
    Has anyone experienced poblems concerning toner adding.
    Noticed that the toner bottle did not turn when toner had to be added.
    as if the toner drive motor was "hanging".
    So I ordered a new toner drive assy, installed it, not that easy!
    however, the bottle did turn and the machine was ready after a time of toner adding.
    Now, 2 days later, customer called again with the same error concerning the toner adding.
    And again, toner bottle attemps to turn but it keeps "hanging" again . . . .
    someone a clue here??
    Thanks in advance
  • FrohnB
    • Jul 2017
    • 1919
    Re: MP5054
    Is this a new machine? With this series you have to Initialize the toner supply system upon first setting up, if not done correctly you will go into a "Toner End" condition even if it's a full bottle. 1st off Try opening the front cover for over 5 seconds, make sure bottle is set properly and then close cover. This should execute a "Toner End Recovery"...... Or, Try turning machine off, then open the front cover and turn machine back on, enter SP mode from the Copy screen, Set SP 3-510-031 to 1 and press #, Exit SP mode, Close the front cover and the Toner should start loading, Wait a few minutes for toner to load, then go back into SP mode, go to SP 7-622-250 (Counter reset) and press Execute, then press "exit", THEN go to SP 3-011-001 (manual Pro Con) and Execute.
    Omertà
