Ricoh MP 2501SP problem after PM
  • sakisvas
    • Nov 2016
    • 33
    Dear friends,
    I have a customer with a Ricoh MP2501 SP with black lines in copies (The machine need PM).
    So i change DRUM, DRUM BLADE, CHARGER ROLLER and DEVELOPER ... (sp2801-001)
    After that the copies have a background ..
    i clean again drum unit, dev unit and only the 2-4 first copies are ok.. the background return!!!!
    i changed the charger bias (-2000 ) and the copies were ok.. but only for 2 hours !!!! My customer call me again that the backround return!
    Thank you very much
    Sakis
  • solorajder
    • Jul 2010
    • 106
    Re: Ricoh MP 2501SP problem after PM
    Is it drum original? I have the same problem with Katun drum.
    Sent from my G8441 using Tapatalk
    • keithxxiii
      Just a tech
      • Nov 2014
      • 471
      with this models, if you dont use original parts, you will have to suffer with this kind of problems. Make sure your PM Parts are OEM including the toner.
      Aye! Cut the crap
      • sakisvas
        • Nov 2016
        • 33
        No the drum is KATUN!!
        Thank you
        • solorajder
          • Jul 2010
          • 106
          Thank you
          You don't need to change developer again, just install original drum.
          • sakisvas
            • Nov 2016
            • 33
            Thank you.. I will install original drum..
            But I have use
            Katun drum in other ricoh mp2501 without problems.. Why??
            • sandmanmac
              • 3990
              But I have use
              You've basically answered your own question.....because the manufacturing process and/or the source of generic products and supplies can change at any time, so yes, it might work fine one time (or many times) and fail the next.
              BTW.....Did you use the correct Developer and not the type for the MP2500? They're NOT the same.
              • sakisvas
                • Nov 2016
                • 33
                I used D1589640 Developer.. Is it OK?
                Thank you.
                • keithxxiii
                  Just a tech
                  • Nov 2014
                  • 471
                  Thank you.
                  Yes, that's the one!
                  Aye! Cut the crap
                  • sakisvas
                    • Nov 2016
                    • 33
                    ok
                    do you believe that i can not fix the problem with some adjustments? the problem is OPC?
                    • solorajder
                      • Jul 2010
                      • 106
                      ok
                      I tried but no success. I have this problem on two machines, at first machin the problem appeared after 10k copies, on secund machin the problem appeared immediately. Since then I only used original drum.
                      • Polarbear
                        • Feb 2012
                        • 1070
                        Hi all
                        If you do a close comparison between the black gear (drive end) of the drum, you will see that Ricoh changed the shape of it.
                        The "compatible" (Katun) drums still use the old shape gear and this allows them to move around in the pcu, as the gear part is shorter than the "new" one.
                        This causes grounding issues = background.
                        Press the GREEN button!!
                        • sturmtrooper
                          Copier Combobulator
                          • May 2016
                          • 587
                          Originally posted by Polarbear
                          Hi all
                          These machines use the same B039 9510 drum as many other previous ricoh copiers. I don't see how the gear would be changed unless katun drums are using the gear shape of some 20+ year old drum that ricoh doesn't make anymore.
                          • keithxxiii
                            Just a tech
                            • Nov 2014
                            • 471
                            Adjustments won't do it. It will work for a few copies/prints then come back again. Sorry but use OEM drums.
                            Aye! Cut the crap
