Ricoh sp 4500
  • Transam1
    • May 2011
    • 48
    Ricoh sp 4500
    does anyone know how to reset the maint message on a ricoh sp 4500 after replacing the maint kit
    Gary
  • FrohnB
    • Jul 2017
    • 1919
    Re: Ricoh sp 4500
    Do you mean MP 4500 , B/W machine? If so then you have to go into Service Mode and in the 7-xxx section there will be counter resets.
    Omertà
    • jonhiker
      • 661
      Re: Ricoh sp 4500
      This is a printer. If the maintenance counter is not reset when replacing the units, then you need to go into service mode and reset them from there.
      It does happen every now and then.
      • FrohnB
        • Jul 2017
        • 1919
        Re: Ricoh sp 4500
        Where does one find this printer?? I've seen SP 3500 or SP 4510, but have never seen an SP 4500. There's an AP 4500, from way back, like 20 yrs ago? Is it not an NA model?
        Omertà
        • sandmanmac
          • 3990
          Re: Ricoh sp 4500
          Having no personal experience with these models, as far as I can tell, the kit that was used and supplies are referred to as type 4500, and used in the SP4510dn/4520dn, etc printers.
          And that's on the poster for not being clear
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            Re: Ricoh sp 4500
            New unit detect is turned on by default.
            No need to reset anything.
