SMB scan
  • kopirmaster
    • Apr 2011
    • 70
    SMB scan
    Hello to everyone.
    I have problem with last update on windows 10 with scan to folder wia smb .Machine network support firmware is up to date ,smb 1.0 feature is check .everything is normal and it works since last windows update . Does someone know what can cause the problem and how to fix this situation .
    • 36857
    Re: SMB scan
    What is the machine model?
    • guitar9199
      • Sep 2016
      • 1099
      Re: SMB scan
      Check your Network Connection, and make sure it's not set to "Public". Then go into Control Panel> Network and Sharing Center. Go into the network port being used, click "Properties", then select IPv4 Properties>Advanced... click the WINS tab, and change to "NETBios over TCP/IP. The default "NETBios over DHCP" doesn't play well with SMB.
      Back in Control Panel, go to Windows Firewall>Advanced Settings, and under your Inbound Rules, make sure all instances of "File and Printer Sharing" are set to "Allow".
      • kopirmaster
        • Apr 2011
        • 70
        Re: SMB scan
        Mp 201/301 .
        • kopirmaster
          • Apr 2011
          • 70
          Re: SMB scan
          Thanks, i will try tomorow and update the status here .
          • kopirmaster
            • Apr 2011
            • 70
            Re: SMB scan
            Finally i found what cause the problem . With last update on windows 10 you have to check "file and printer sharing over smbdirect" in windows firewall .
            Thanks to all .
            • DougD
              2020 Retired
              • Sep 2016
              • 76
              Re: SMB scan
              Thanks to all .
              Interesting.
              My test mule running Win 10 1809 only required a firmware update on my MP 171 to setup scan to folder.
