Scan to email - not using users own email address?
  • OutlawTorn
    • Aug 2008
    • 189
    Is there anyway to use the administrators email as the address that all emails appear sent from?
    At the moment the user scans to themselves but the sender also shows up as from that users email address.
    This is going to cause us issues with emails being seen as spoofed.
  • guitar9199
    • Sep 2016
    • 1099
    Re: Scan to email - not using users own email address?
    Sure... Just set the Administrator email as the default email address under your SMTP settings.
    • OutlawTorn
      • Aug 2008
      • 189
      I have tried this however the email is sent from whichever user has scanned - I'm guessing this is tied into user authentication?
      • OutlawTorn
        • Aug 2008
        • 189
        Machine is an MPC4504 and strangely if I use the 'Quick Scanner' option instead of the fuller 'Scanner' option this works fine?
          • 37240
          In the address book disable Use as Sender for all senders. This forces it to use the default sender.
          • OutlawTorn
            • Aug 2008
            • 189
            Ok I have unticked the 'Use name as Sender' option on all users in the address book.
            I now get 'An error has occurred' when I try scanning? I have a mock address in use for the administrator and this is set to auto specify sender name on.
            *UPDATE* Unticked the scanner option under user authentication management and this fixes it - ideally I would leave the code on here.
            • spacemole
              • Jun 2021
              • 5
              have you tried going to "User tools --> System Settings --> File Transfer --> and change auto specify sender name to yes?
                thanks for the info
                typically we consider a thread dead 2 years after the OP post.
                • mojorolla
                  The Wolf
                  • 2583
