SC700-07 MPC6003 SPDF3080
  • manoj.k.nair
    • Sep 2012
    • 50
    [Error Code] SC700-07 MPC6003 SPDF3080
    Hi team
    I am facing an issue with a single pass DF. SC 700-07. If anybody faces this issue, kindly update.
    ............first, it showing paper jam in P..... OPEN COVER AND REMOVED JAMMED PAPER.
    if you check the machine status it is showing SC700-07...
    TNX.
    MANOJ
    M N AIR
    • 37474
    Re: SC700-07 MPC6003 SPDF3080
    Trouble the SC 700-07 as that IS your jam. As with finishers and other peripherals, a service condition will first be reported as a jam.
      Originally posted by manoj.k.nair
      Hi team
      TNX.
      MANOJ
      well now that you know WHAT the problem is... what have you tried to correct the issue?
      we can make suggestions all day long.. to no avail , if you don't inform us of what has been done!
      " Doctor.... I have this pain in my gut...."
      What have you done?
      well I swallowed a bunch of pain pills and drank a quart of moonshine...
      • adoug
        • 23
        The error code relates to the Scanning Motor Error (1-pass ADF,so I would start with that and trouble shoot from there mate
        • manoj.k.nair
          • Sep 2012
          • 50
          Hi team
          TNX.
          MANOJ
          Hi
          THIS PROBLEM HAS BEEN SOLVED WHILE REPLACING D683-1822 SCANNER DRIVE MOTOR.
          TNX.
          M N AIR
