sc 552-02
  • claudioterrible
    no mercy...
    • Oct 2008
    • 96
    sc 552-02
    Sorry friends ,i have a mp 5054,and the sc code sc 552-02 is on display just after replace the pressure roller thermistors.Read the manual and is bout thermopile ,but it seems ok ,any idea about this problem? thank you!!!
  • JDYAL
    • Sep 2008
    • 186
    Re: sc 552-02
    Did you test the thermpile with your meter?
    • adoug
      • 23
      Re: sc 552-02
      Was the code present before you replaced the thermistors?
      Did you check the connection on the pressure roller thermistor to make sure they are seated and sitting correctly...
