Ricoh C9110 SC 590-01
  • Livebychance
    • Dec 2007
    • 34
    Printer only version C9110 SC 590-01 will not go away.
    Things we have tried:
    Swapped assemblies with another color
    Turned off in Sp mode rebooted
    2-220-001 O no operation
    Replaced BCIU
    Replaced IOB1 board
  • guitar9199
    • Sep 2016
    • 1100
    Re: Ricoh C9110 SC 590-01
    Cleaning Pad HP Sensor working?
    Charge Cleaning motor turning?
    • Livebychance
      • Dec 2007
      • 34
      Thanks for the response.
      We swapped the entire assembly with another color. Sensor motor off another color still same SC code
      We rebooted the machine with the doors open and as soon as we closed the doors the code appears.
      It does not seem like it's even trying.
      • Rorschach
        • Nov 2008
        • 65
        When you say assembly, do you mean the corona itself?
        I might lean towards a wonky power supply. PSU3 is the one that the corona cleaning motors get their 24V from via IOB1. I don't think there's a relay board involved in that particular circuit.
        Connectors 300, 301, and 369 on IOB1 all get 24V from PSU3. Put your meter on them to see if you're getting the 24V where you should be.
        If you're getting 24V on all the red wires in those harnesses, you might have a bad harness or short somewhere between IOB1 and the motor. Those harnesses are zip tied to others that go to several HVP - there might be a pinched wire, or the zip ties may be too tight. Also, CN334 on IOB1 is the connector for the harness to the corona cleaning motors. Pins 1 and 2 look like the ones on that connector that supply the 24V to the motor.
        Today's subliminal quote is:
        • Livebychance
          • Dec 2007
          • 34
          Hey Thanks Rorschach . Very good trouble shooting skills on your part.
          Replaced corona assembly
          No 24vdc
          Replaced PSU3
          No 24vdc
          Will look at the harness
          Also, thinking way outside of the box what about the Fiery?
          This one seems stable however we have experienced unusual symptoms that we had to reload Fiery in order to clear an SC code.
          With the color production printer only versions. 720, 900, 901.
