driver download file (*.inf) - disappered when "adding new printer"
  • Mark Bbb
    • Jun 2012
    • 1662
    Using "add a new printer" it asks at a certain time for "copy file driver" (or something like that).
    Then (than?) you select "bladeren" (i don't know the English word for it) to select the driver file which you had downloaded on the pc before.
    But... this driver file is nowhere to be find (*.inf)...
    But the file is actually in the "temp" root (or at "desktop") visible...
  • Kimi
    • Feb 2018
    • 105
    Re: driver download file (*.inf) - disappered when "adding new printer"
    You have extracted the file?
    • B0265
      • Jan 2007
      • 718
      The file name + the path might contain too many characters, try putting the driver files directly under C:\
      • Mark Bbb
        • Jun 2012
        • 1662
        Almost daily we install printers and drivers and sometimes this driverfile is not found in the root after "new printer" is added and when it asks for the driver.
        Although the driver file is saved in the temp map and is accessible via windows explore or search file.
        • Kimi
          • Feb 2018
          • 105
          make it simple and save to desktop?
          • Mark Bbb
            • Jun 2012
            • 1662
            Kimi: that is what we have tried to do also, but no good...
            File is not found at the point of "select driver file of manufacturer"...
            • keithxxiii
              Just a tech
              • Nov 2014
              • 468
              how about replicating the issue? on a different PC?
              Aye! Cut the crap
              • AjitN
                • Mar 2009
                • 287
                A screenshot of driver installation & explorer will help much better
                • NeoMatrix
                  Senior Tech.
                  • 3514
                  Sounds like UAC problem....
                  Download the printer driver using known User (not Guest) or Admin account.
                  Try installing the printer driver using administrator account.
                  "Install this driver for all users"
                    • 36970
                    If you have the problem with multiple machines of the same model, try downloading and/or extracting the driver to a folder USB or SD memory device. This way you will have the extracted driver where you can copy the folder to the desktop of each machine.
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      Slim: we will follow the procedure with the usb stick, thank you.
