Wiring diagram for ricoh products
  • AjitN
    • Mar 2009
    • 287
    [Electrical] Wiring diagram for ricoh products
    Greeting
    Does any body know where I can find wiring Diagram for Ricoh MPC 2011?
    I think wiring diagram is not a part of service manuals for Ricoh. Either it is provided separately OR Ricoh has not made it at all.
    Wiring diagram will really help me(& all) a lot during fault finding especially in case of electrical problems.
    Regards & thanks in advance
  • Lagonda
    • Aug 2008
    • 1649
    Re: Wiring diagram for ricoh products
    Wiring Diagrams haven't been part of the Ricoh service manuals for a long time now. Try looking on your local Ricoh tech website for the MP C2003 and 2503 as they are the same as a MP C2011.
      • 37556
      What you want is the POINT TO POINT diagram. Shows the connection between between all components in block diagram mode. Connector number are shown with pin out tables for each connector. With newer models that do not have cable part numbers in the Pats Catalog, they are listed on the P to P.
      • AjitN
        • Mar 2009
        • 287
        Sir I want something like this.
        Please check my new thread "C Q problem in MP C2011".
        There are no codes or error logged. So don't know how to start & which parts / boards are faulty.
        We I get such wiring diagram, I can check the output of different parts, control signals etc.
        Regards & Thanks for replay
        • keithxxiii
          Just a tech
          • Nov 2014
          • 471
          I have been servicing Ricoh for ages and haven't seen anything like it. Ricoh has point to point diagram that shows all the connections and everything you need to know about the parts.
          Aye! Cut the crap
            like MANY have been saying... you require the POINT to POINT diagrams that are in the manuals...
            in your ERROR log will be error codes NOT SEEN on the display.
            CQ problems MOST times on Ricoh products can be narrowed down by looking and comparing the Birth Cert values to those on the machine currently and working thru the differences.
            • NeoMatrix
              Senior Tech.
              • 3513
              You want an electrical block diagram?
              An electrical process flow chart?
              Ricoh company identifies their electrical "schematic diagrams" as "Point to Point" diagrams.
              • AjitN
                • Mar 2009
                • 287
                OK, so where can I find those Point to Point diagrams?
                • davel
                  • Oct 2011
                  • 1107
                  Local Ricoh website where you find manuals.
                    they aren't in the SM anymore? I guess because they make the units " modular " they feel techs no longer know how to use Ohm meters.. scopes n such? wow talk about dumbing down the work force.
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      And only available to Ricoh Authorised techs via the Ricoh portal for your region.
                      • paulg
                        • Jun 2007
                        • 278
                        Point to points can be found in the 3d parts manuals and not sure who else uses but the TDC in the UK normally has p2p for the copier your working on.
                        I can remember circuit diagrams for boards used to be available a long long time ago. One guy once asked a trainer in a Ricoh training course at Feltham in the UK many years ago and he said the diagrams were no longer supplied to Technical Support due to copyright and patent issues.
                        • AjitN
                          • Mar 2009
                          • 287
                          I think Ricoh don't want own engineers / Dealers or third party service provider to support their products effectively.
                          I think thats why Ricoh is slowly loosing their market share as end users do not want them self to get handicapped
                          • tufbnme
                            • 493
                            Heres the c2003.2503. Cant locate the C2011 without a product code.
                            MPc2003 2503 PtoP 1.pdfMPc2003 2503 PtoP 2.pdf
                            • LiranHershman
                              Electrician can know well about these diagrams and many times i have talked with them about it.
