Latest models with older Equitrac installation
  • mrwho
    Major Asshole!
    • 4299
    [Misc] Latest models with older Equitrac installation
    Good evening gang.
    I was asked this today and I wasn't sure how to answer, so I'm turning to you in hopes of clearing this doubt:
    A current customer with an existing installation of Equitrac Express (version 4) can add a recent machine with the lastest version of PCC installed? Or will this demand an upgrade from his existing version of Equitrac?
    Thank you for any insight.
    Mascan42
    Ibid
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: Latest models with older Equitrac installation
    Originally posted by mrwho
    Good evening gang.
    I believe that Version 4 was a Java based version and the card reader connected via the controller USB ports.
    PCC 5 (Nuance) requires the panel version of the card reader.
    I'm prettry sure he'd have to update PCC.
    • mrwho
      Major Asshole!
      • 4299
      Thanks for the feedback, but what I'd like to know is if they'd have to upgrade Equitrac or if the new PCC would work with the old version 4.
      Mascan42
      Ibid
      • keithxxiii
        Just a tech
        • Nov 2014
        • 468
        PCC5 works with Equitrac V5.6 and above.
        If the client is not going to use Autostore, then downgrade it to PCC4
        If yes, then upgrade the Equitrac to 5.6 and above.
        Aye! Cut the crap
        • TonerMunkeh
          Professional Moron
          • 3865
          You can put PCC4 on the newer kit and use the Mifair card readers too.
          Hit it.
          • mrwho
            Major Asshole!
            • 4299
            Thanks.
            So it is possible to use pcc4 in the newest machines? Nice to know - Equitrac 4 is plenty enough for this customer as it is.
            Mascan42
            Ibid
            • TonerMunkeh
              Professional Moron
              • 3865
              Yes indeedy.
              Hit it.
              • rsyarcia
                Hair Straightener Tech
                • 711
                Check this out - Equitrac: PCC compatibility.
                Nobody is perfect..
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  Last Friday I did a PCC v.4 install and used the v.5 NUANCE card readers to run it.
                  They're the panel version card reader but I used the rear USB slot and it worked like a charm.
