MPC4000 gets sc700 + sc701 after warmup
  • axyun
    • Aug 2007
    • 1323
    MPC4000 with error SC700 + SC701 after warmup . When it does go into ready it does not detect document. Is this usually one of the orig. stopper home position. sensor or Pickup roller hp sensor? This is from customer who is pretty good and whose inf usually reliable. . Any advice you could give before going there would be
    much appreciated. Will check manual for spmode checks. Frank
    • 37379
    Re: MPC4000 gets sc700 + sc701 after warmup
    SP 700 Original stopper HP error
    SP 701 Pick-up roller HP error
    The original stopper is the fingers in the bottom of the feed table. The mechanism that controls them can also prevent the feed shoe from being lowered to the paper(to prevent trying to feed paper when the stopper is in the up position.
    • axyun
      • Aug 2007
      • 1323
      Thank ou Slimslob. I'll post results once I am able toschedule and check mout.Frank
      • axyun
        • Aug 2007
        • 1323
        It turned out to be the the timing pulley with a cracked gear. It was unable to turn the pickup cam. Temporarily glued it and ordered part. Working for now.Frank
        • skinnyb
          • Jul 2008
          • 291
          Had this problem this week myself. Glued and parts on order too...
          Sent from my VS987 using Tapatalk
