Single sided A4 Sheets works fine from all the trays.
Only when Duplexing get paper jam at Point B.
When the paper exits the bottom of the duplex machine, going towards the registration and the idle roller, past the registration sensors.
I have cleaned the registration sensor, the SP5 -803-9 shows up as detected (7) (00000001) (0).
I have replaced the following parts:
1 x AX20-0240 (reg clutch)
2 x AX20-0239 (relay clutch)
2 x AX20-0224 (feed clutch)
Any ideas what else I need to check?
