MP C2503 Hard Drive replacement procedure
  • copydocinc
    • Mar 2015
    • 263
    I've never replaced a hard drive on a Ricoh. Is there special requirements, like firmware upgrade or special reset tool or what not?
    I have a customer that is turning in their leased Ricoh MP C2503 and want the old hard drive out and a new one put in before they turn in the copier/printer.
    Can I just remove the old one and put in the new one and I'm done or tell me please?
  • keithxxiii
    Just a tech
    • Nov 2014
    • 469
    Re: MP C2503 Hard Drive replacement procedure
    When you insert a new hard drive, the system will auto format it. Then you can start using the machine.
    Aye! Cut the crap
    • guitar9199
      • Sep 2016
      • 1100
      I always update the firmware when replacing the HDD. It's a pretty easy process.
        • 37532
        On the Ccc03 it is always to at least check for firmware updates once a month. When they first came there were new updates released 3 and 4 times a week.
        • davel
          • Oct 2011
          • 1107
          If they have any software or apps loaded on the drive you will need to uninstal first then replace drive with same or larger capacity. It will detect new drive and ask to format it. You may also need HDD encryption key.
          • paulg
            • Jun 2007
            • 278
            Make sure you note the jumper settings of the original HDD and ensure you format once back in just to make sure all is ok.
            • davel
              • Oct 2011
              • 1107
              Do SATA drives have jumpers?
              • keithxxiii
                Just a tech
                • Nov 2014
                • 469
                he must be referring to those MPC4500 HDDs. 2 IDE HDDs, similar size.
                Aye! Cut the crap
                • skinnyb
                  • Jul 2008
                  • 291
                  Nope.
                  Sent from my VS987 using Tapatalk
