spc842/xante enpress questions
    • 37448
    #16
    Re: spc842/xante enpress questions
    Do you grave robbers realize that this was started over a year ago. That makes it dead and should remain buried.
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      #17
      I need to bring it back to life. Does anyone know if they messed with the fuser or can I use a sleeve assembly from Ricoh.
      • tuey
        • Apr 2014
        • 120
        #18
        i use ricoh fusers, drums and developers and t. belts in the xante- no adjustments needed. have company from australia that does toner chips.
          • 37448
          #19
          Which means that you use after market tone and therein is the probable cause of the noise. There is only one after market manufacturer whose toner meets Ricoh's quality standards and testing and they are just as expensive as Ricoh and do not require replacement chips.
          • tuey
            • Apr 2014
            • 120
            #20
            only ever used xante toners, but you can use ricoh in the xante if you change the chip. i think you're confused
