Savin 2404wdp SC547
  • DougMoney
    • Feb 2017
    • 70
    Savin 2404wdp SC547
    I am working on a Savin 2404wdp that threw a SC547 code. I have read that it could be a fuse, circuit breaker, noise on line, pinched wire, loose connection, power supply, etc. Anyone have any more targeted places to check?
    Thanks.
  • JDYAL
    • Sep 2008
    • 187
    Re: Savin 2404wdp SC547
    Make sure your clam shell switch is making contact, had this happen and threw a 547. Also check your fuser unit, lamps, thermopiles, and thermistors. I have been working on these machines since they came out and have only replaced 2 power supplies in 10 years.
    • guitar9199
      • Sep 2016
      • 1100
      Check the line voltage coming in. These are great tools to have in your kit.....
      https://www.amazon.com/Mastech-MS590...a-571641192638
      You might also check if something ELSE is plugged into the AC circuit that the printer is connected to. Space heaters and such cause quite a drain on a line, and can cause copiers/printers to do strange things.
      • DougMoney
        • Feb 2017
        • 70
        It ended up being the switch for the rear door. The actuator had broken off of the door partially.
        I've never seen one through a code doing this. Thanks for the help.
        • JDYAL
          • Sep 2008
          • 187
          Yeah the switches will make these machines throw odd codes sometimes. Glad that you figured it out.
