HDD Unit on SP 5210SF and SR
  • ABS tect
    • Sep 2013
    • 511
    I got a good bunch of Ricoh SP 5210SF's and SR's in recently but none with a Hard drive in them. From what ive seen these are not an option on this unit like the MP 201.
    So i am about to order some and i was wondering if you could help me out on what is the standard size and type of hard drive that these use. Thanks!
  • guitar9199
    • Sep 2016
    • 1100
    Re: HDD Unit on SP 5210SF and SR
    D1055705 -HARD DRIVE 2.5 SATA
    Got this from Hytec.... $89 each.
    Also check M3445130, D3625130, or M3085130.
      • 37393
      If a machine does not have DOSS installed, if the previous customer is concerned about the security of their data on the HDD, you are supposed to remove the HDD and hand it to the customer's IT.
      • fshead
        • 2368
        i am mucking wth 2 SP 5200S that came in without HD,but did have harness.
        I am thinking any laptop sata 2.5 160 gig drive will work.
        It might even work with a 80 gig if you have some laying around..
        I just actually unwrapped them 2 days ago so have not done much more than
        pull the box and see no drives
