SC 370-02 in MP C3503
  • rhe
    • Feb 2013
    • 51
    Hi
    I Have replaced ID sensor,i/o board imaging,paper transport board,BCU,high voltage boards both(PCDU,TRANSFER) but still same error.
    it starts first with door open then sc 442 and now machine is continue showing sc 370-02.
    Also transfer belt unit is new.
  • mikadonovan
    • May 2008
    • 2931
    Re: SC 370-02 in MP C3503
    According to the Troubleshooting guide, if your getting a sc370, engine firmware must be at 1.25.08 or higher. A sc442 indicates engine firmware needs to be at 1.31.01 or higher.
    NEVER ASSUME ANYTHING
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      Gonna be slightly embarrassing if he's swapped out boards without doing FW
      • mikadonovan
        • May 2008
        • 2931
        Good point. The engine firmware may reside on the bcu.
        • davel
          • Oct 2011
          • 1109
          What was the original problem. I just had 370 on a MPC4504 because the belt was in pieces on top of the machine and now I am off on leave.
          Merry Chrismas everyone.
          • rhe
            • Feb 2013
            • 51
            Hi
            All firmware are also at latest level.
            • Brianneoe
              • May 2015
              • 322
              The center sensor is being blocked because the shutter is not opening all the way. Yes it could be firmware but I would check the shutter first. Had this at an account that was a 2 hour drive one way. Removed the shutter and all was good.
                • 37652
                If you are referring to the shutter over the ID sensor, on the ITB unit check that the latch cam on the back is not damaged. If it is it will allow the ITB to move slightly when the shutter is opened. (voice of experience)
